Title | Size | Downloads |
H3C MSR 20 Routers Installation Guide(V1.05)-book.pdf | 2.17 MB |
Preface
The H3C MSR 20 Routers Installation Guide describes how to install the H3C MSR 20 Routers, maintain software and hardware of the router, and solve problems you may encounter during the installation process.
This preface includes:
· Audience
· About the H3C MSR documentation set
Audience
· Field technical support and servicing engineers
· Network administrators working with the MSR Series
Conventions
This section describes the conventions used in this documentation set.
Symbols
Convention |
NOTE |
Network topology icons
The H3C MSR documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Describe product specifications and benefits. |
Hardware specifications and installation |
Provides a complete guide to hardware installation and hardware specifications. |
Software configuration |
Describe software features and configuration procedures. |
Provide a quick reference to all available commands. |
Describe Web software features and configuration procedures. |
Operations and maintenance |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
